jjrbus
Jul 22, 2016Explorer
Thanks for the response. Last Motorhome I installed a diesel genset and used the hi tech foam with a lead sheet floor, great stuff but $$$$. A little shopping and it is available much cheaper than West Marine. There was a seller in Tampa, about 100 miles and it was worth the drive to go there for it! Plus they let me go through their scrap for bits and pieces.
This time with the little Toyota camper weight is a big issue and I want to do it on the cheap. I just bought some U seal self adhesive repair tape from Lowe's it is similar to Dynamat but waaay cheaper. Not as good, but will do.
I am thinking I will not use it in the cooling air exhaust area?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
