jjrbus
Jul 28, 2016Explorer
I have been Toying with this and have tried to mimic what others have done. I started in a different direction so mine is somewhat different.
This is a picure with the top off for viewing. The issue I am having is the case keeps getting what I consider too hot. At full throttle the temp at the base of the handle on the exhaust end reaches 125°. Adding the fans will drop the tempature several degrees. Removing it from the case and the temperature quickly drops to about 100 at full throttle on a 90° day in Florida.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
