jjrbus
Aug 03, 2016Explorer
bcbigfoot wrote:
I doubt you will get accurate temp readings from any of the exterior of the Honda. You have placed the Honda in a box that reflex all radiant heat back at the Honda's surface. Like a big red baked potato haha. The temp you are getting is really just superficial, try getting a temp inside the Honda's red case, the actual air temp the Honda is seeing.
Thanks for the response and you are right. plus I do not have the equipment to obtain 100% accurate readings.
But I can get a baseline "good enough" temp and watch for differences from that. Close enough to tell if my tinkering is helping or hurting.
So far I believe I will keep the two exhaust fans, I am not comfortable with the temp rise without them.
Jim
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
