jjrbus
Aug 04, 2016Explorer
bcbigfoot wrote:
I used a 6 dollar car interior/exterior temp gauge, the external probe/sensor had a approx. 10ft wire. I taped the wire of the sensor to several spots on the interior of the Honda, I made sure the sensor didn't touch hot engine parts just air working its way through the Honda.
Brilliant!! Now why did I not think of that:S At this point mine is running about 10° hotter in box also. Experimenting with mock ducts and fan placement I suspect that is the best I will do without the addition of a large fan. From my tinkering I also suspect the Jorgenson sp? is running much hotter and I can see where Soundguy would be running cooler.
It is too late for this experiment, but I am ordering one of the temp gauges for something else. I notice the max temp on these is 158° did you reach that in your testing?
Thanks for the response greatly appreciated
Jim
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
