navegator
Sep 22, 2015Explorer
Before you install the heating element, make sure that it does not touch the heating tube, some times the welded fitting is off a bit and when the heating element is tightened it will touch or some times pierce the aluminum heat tube and you will end with a leak.
Measure from the thread to the end and use a tape measure to probe for depth, be sure that the tape is going in the same direction as the heater element or use a piece of wood to probe for clearance.
navegator
navegator
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
