Vach's avatar
Vach
How are my solar panels doing?
First time extended camping with my new panels and I would like to know what others think of their performance. I have two 140 watt panels and a Morningstar sunsaver duo charge controller. Highest amperage has been 12.25 which I think is pretty good. Most days peak is 7-8 amps. Highest voltage has been 14.2 volts, mostly in the mid 13's though. Controller is Programed for 14.8 volts max charge. Most mornings the batteries "rested" voltage is 14.3 to 14.4. 8 gauge wire from panels to charger and short run to bats. I read extensively and believe the install is good.
Should I be getting more than 8 amps with full sun under these conditions? Plugged in back home I did see 15.0 volts at one time. Bats are watered, no shade, connections tight. Thanks for the input.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
