StirCrazy
Apr 04, 2024Moderator
you could hook there, but you would need a regulator for the external tank you use and you would have to find out what the flow rating for the quick conecy is and if it is high enought to meet your usage demands, as in furnace and stove at the same time.
- Rolling_CondoOct 24, 2024Explorer II
Look up Extend A Stay.
- StirCrazyOct 25, 2024Moderator
why do I need to loo it up.. I have no use for them. I was ansering the question of weather he could hook up to the quick conect, which the answer is yes if you reduce it..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
