kaileybutler052's avatar
Oct 22, 2022
How do I know what kind of heating is in the caravan?
Dear, please tell me how to understand from the description, what heating system is in dachlüftung camper: liquid or air? Here they write in the description: "central heat", how should this be understood? As I understand it, if it says "Truma", then it is air?
  • kaileybutler052 wrote:
    Dear, please tell me how to understand from the description, what heating system is in the caravan: liquid or air? Here they write in the description: "central heat", how should this be understood? As I understand it, if it says "Truma", then it is air?
    It sounds like a Truma Alde system. That is a hydronic heat and hot water system. A propane burner and/or electric element heats glycol which is then circulated through a series of heat registers in the trailer. Dry quiet, super efficient. It’s a common system on higher end trailers. They have excellent reputations.
    Hope that helps.
  • Truma makes tankless water heaters. The main heating systems in RVs are LP/Propane furnaces. The heat source is the LP and the fan and thermostat operate on 12VDC from the battery.
    Rob
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
