Flyin_Finn's avatar
Flyin_Finn
How I repaired my damaged section of my fiberglass wall
Hi all, first, apologies, I haven't been on here for a few years.
I was going through my old photos and ran in the ones from 5 years back when I replaced a large section of the damaged fiberglass wall on my 5th wheel trailer.
I had intended to do a write-up of my experience, but never got around to do it. So now I finally did it and posted it on my website, and I might add, that 5 years later, the repair is holding up well!
I don't recommend this repair, unless you really know you can pull it off.
Since I am logged on here again, hopefully I will spend more time here now. I still use my (now old) 5th wheel, still pulling it with the same old truck :).
Before and after:
Link to the repair write-up: RV sidewall damage repair
  • Your repair looks great Finn! Good to know that filon can be seamed like that and look decent!
  • Flyin Finn wrote:
    Btw, thanks, all, for the compliments. It wasn't a perfect job, but not bad either. It is holding up well, so I am happy.
    Most factory applications and not perfect either.
    Great job!
  • Btw, thanks, all, for the compliments. It wasn't a perfect job, but not bad either. It is holding up well, so I am happy.
  • BurbMan, wow that Lance project was quite a job! Well done!
    Lots of similarities with my case although my project time- and effortvise was only a small fraction of what yours was.
    I am sure the filon and the adhesive is the same as I used.
  • Nice repair job. My last 5th wheel had damage to the same area, though not as large, when a garbage truck clipped the front corner. I had local RV body shop repair it & because I knew exactly where to look, I could see where the filon was repaired, but I really had to look at just the right angle. Good repairs can be done.
  • I'm at work now but once home, I will check out the Lance build and comment some more.
    It is so long time I don't remember the adhesive. I could try find out later. It is the red stuff in the images. If I remember correctly it is meant for manufacturing application and not available in retail stores. It is sprayed on on both surfaces and let dry then attached together and needs to cure under pressure.
  • Gjac's avatar
    Gjac
    Explorer III
    Very nice job. Did you use a contact adhesive?
  • Nice job! When I re-did the truck camper, I took off the rest of the side and replaced the whole wall (actually 3 of them) but your trailer would need a LOT more filon. I attached the luann first then sprayed the adhesive on, laminated the fiberglas in place, then trimmed the excess with a router.
    Here's my Lance build, summer covid project.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
