MNtundraRet
Jul 01, 2024Navigator
Ponylady97 wrote:I have a question, I have a 2017 Coachman Leprechaun 260QB and I am trying to drain the fresh water tank. I have located the valves in the pictures but not sure what to open and/or close. I believe the 4 lines with the valves are my low point valves but not sure why there are 4 and should I open all of them to drain the fresh water tank? The other valves attached to the water are all open except one and I don't think I need to do anything to these to drain the tank. Any help would be appreciated, thanks.
I never drained ours except at the end of our camping season. I just pumped the water into the holding tank by turning on a few faucets. If you have low-point valves emptying under the trailer you can drain the lines, there.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
