ewarnerusa
Jul 02, 2024Nomad
The Styrofoam-insulated tank looks like your hot water tank with the three valves set for normal use. I can't tell what the picture with four water pipes with valves is, I don't have something like that in my camper.
My low point drains do not have a valve on them, just a screw-in cap. they just drain the plumbing lines as open spaces describes. They are located on the outside underneath the camper. My freshwater tank also has its own drain hose with screw-in cap (no valve) located outside underneath the camper.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
