goducks10
Apr 10, 2016Explorer
Assuming your roof framing is 16-24" OC, why not put a piece of aluminum 2"x?x1/8"+ or equivalent to span the framing members. Then fasten the solar panels to the aluminum strips. I would use pointed sheet metal screws for the aluminum strips. Self tapers in thin aluminum could strip out too easy.
I would also run the fasteners for the solar panels up from under the aluminum strips using counter sunk machine screws. That way you only have the bare minimum required screws into the roof.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
