djgodden
Apr 12, 2016Explorer
I did exactly what you're doing about 3 months ago. After a lengthy bit of research and practice I use 1/2 well nuts. Drill a 1/2 hole, lap sealant around the top, insert the well nut, a dab of lap sealant on top, place solar panel, screw in place (the rubber well nut expands and seals and grabs the roof, more lap sealant ontop of the screw.
Did a number of hard yank tests and there's no way these are moving. My Montana has an aluminum frame.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
