93Cobra2771
Jul 27, 2016Explorer
DD716TED wrote:
If the back side of your external shower is unaccessable and in a cold space as mine is.. don't forget to figure out a way to drain it in cold weather.. I didn't and it froze breaking the fixture.. I have no idea why the low point drain wouldn't empty it even with the hose removed but it didn't..I think there is some type of check valve in the fixture?? Now I don't use it at all..
Low point drain isn't enough for winterizing. You should run RV antifreeze through all the lines. Or at least blow them out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
