sprintstream
May 10, 2015Explorer
Thanks for all the replies. First the water heater is new and is only 15 amps and according to the specs it can only be expected to raise about 20-25 deg. The 20-30A heaters have a much higher temperature rise capability. The heater I was thinking about is like
http://www.amazon.com/Kats-13150-Aluminum-Circulating-Heater/dp/B000BQUUR6/ref=sr_1_2?ie=UTF8&qid=1431292938&sr=8-2&keywords=engine+block+water+heater
I believe the point about the heat rise to the cabin may be the best argument against this. I too wonder about the potability safety but figure something could be found.
I have no room for a bigger propane heater and the propane capacity is depressingly small. Any other ideas?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
