sprintstream's avatar
sprintstream
How's this for better tankless water heater use
We have a 2005 Sprinter CLass B Gulfstream. It comes with a tankless heater but since there is limited voltage (and room) available our heater can only raise water temps about 20degs. Not bad when you're sitting in the desert but most times the tank's water temp is 60-70. I've got an idea to first heat the fresh water tank when needed. I think I could maybe use an engine block water heater attached to the tank with a thermostat. Do it overnight and ready in the morning. Maybe a small pump to push through the heater. This way that 20 deg rise become useful.
My only hesitancy is how this will affect the quality of the water in the fresh water tank with rises and falls in the temperature. I know environmental temperatures could do the same thing but I was wondering.
Does this make sense to try or does someone have another idea?
  • I'm not clear on your plan but changing the temp of the water should not affect the quality. If you are thinking about hooking up a 120V engine tank heater that will draw off the same power source as the tankless heater.
  • Most tankless water heaters heat the water with propane. How are you trying to heat the water that only allows you to get to 80-90 degrees (what most folks call cool)?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Jan 08, 2023
