wopachop's avatar
wopachop
Idea for filtered air into the RV
Many people have MaxxAir/ Fantastic Fans. Along with the stock bathroom fan. Normally air must enter through the window drip vents and cracks at the door to replenish the air leaving the RV.
You could take a 4" automotive filter and use PVC pipe to route the filtered air into the RV. The picture shows 4" pipe, but i think you could reduce the 4" down to 2" so that you are only drilling a 2" hole into the floor of your rig.
To avoid confusion the picture shows a 4" filter attached to a 4" marine blower. I think you could skip the blower part and only use the filter. It would be nice to use a higher quality filter. This was just an ebay no name filter.
I put a little computer fan on my ceiling vent. Yesterday i was picking something up and my face was near the output pipe in my trailer. Was surprised how much air was coming through. Made me think that people with a high power MaxxAir vent could totally suck some nice filtered air into their rig.
  • JaxDad's avatar
    JaxDad
    Explorer III
    I’m not sure what kind of chassis you’re talking about, but most have massive air exchange capacity built in, both my E350 and F53 chassis’s do.
  • Naio's avatar
    Naio
    Explorer II
    I spent this winter in valley fever area, so I used a HEPA air filter machine in my van.
    Rather than drawing air in from the outside, it recirculated the air within the van, and filtered it. As a bonus, it also circulated the warm air from the heater very well, and got rid of the smoke quickly when I burned a lamb chop :-)
  • I don't think I would want to breathe the oils from that air filter.
    There's a reason you don't see them in home HVAC systems.
  • I think you could get clever with placement under the trailer. Snuggle the filter between holding tanks. Somewhere naturally blocking the smoke.
    My placement is not ideal for travel. To answer the first gentleman its not travel worthy in wet weather. Plan was to build some type of airbox. Its been 2 years and still havnt done that. Instead i remove the filter and put packaging tape over the pipe. Its a quick solution that works for me. My trailer only moves a handful of times a year.
  • It would be darned nice if that thing could filter out campfire smoke from the neighbors.
  • If you are talking about filtering air to remove virus particles, forget it. You need something like 0.1 micron filters and no Maxair is going to pull air thru one of those filters if you could even find one. The would be rather pricey too. In the Navy we had little air samplers, about the size of a rural mailbox, that filtered air thru 0.45 micron filters that were about an inch and a half in diameter. They were commonly called the 'Cadillac' because you could buy one of the cars for what the pump cost.
    If you are talking about filtering dust out of the air, then enjoy yourself.
  • That's a neat idea.
    If the filter gets wet while driving does it affect the performance?
    Maybe a marine blower would be better (quieter) than running the ceiling fan?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
