MrWizard's avatar
MrWizard
Moderator
Oct 28, 2014
If your looking for LED lighting
consider this for $9.95
12vdc LED 72 lumens per sq segment
20 segment chain, each section 4leds 12vdc..72 lumens ..80ma draw
chain uses 1.6 amps at 12v, 19.2w and producing over 1400 lumens of light
needs voltage regulator
sections/segments can be used separately (remember the regulator or voltage controlled power supply)
12V, +-.5V DC input Only.
20module string of 72 Lumens/Module White LED light engines featuring: 4 high lumen LEDs/module. 120 deg. beam angle.
Current: 1.6A (80mA)/module) Color Temp:~5000 to 6500
Steel case, Peel-n-stick backer, clear epoxy potting. CE /RoHS
Module L.: 1-7/16” W: 1-3/4” T: 3/16"
L.: 115” WT: .44
  • 12 +/- 0.5 is a pretty narrow range. I wonder if they really mean that? I run my LEDs as hot as 14.4V when the batteries are charging.
  • Thanks for the info.
    I've been looking at switching to LED's. It seems that every time I think I know what I want, someone comes up with a better/different idea.
