Almot's avatar
Almot
Explorer III
Nov 11, 2015
If you're thinking LED and not sure
Just go for it.
My trailer had regular 18W wedge bulbs (T9 socket). After much procrastinating went to Ebay and got it.
24 5050 SMD
Brightness - identical to old ones.
Color - identical.
Amps - 5 times less (0.3A per bulb VS 1.5A of the old ones).
Installation - what installation? Pull out old bulb and plug this one in.
No photos, but trust me, they are really identical to old bulbs in color and brightness.
Also got smaller 12 5050 SMD for kitchen hood - didn't fit well, the cutout in the hood is fraction of inch smaller than that LED disc. No big deal, I plugged it in, laying loose inside of the lamp cover.
You do want 300 lumen brightness and "Warm White" color temperature if the goal is an exact equivalent of an old 18W bulb. There are LEDs with higher and lower lumens and whiter-bluer color out there.
My reason for procrastinating was - I'm a light user, under 40 AH a day. Batteries are full every day on solar, cycling from 90% in the morning, 95% Absorb at noon and 100% Full by sunset. Don't even know why I needed LED, just did what everybody did. Maybe will need it later in short winter days.
Here is a catch - now I'm spoiled and find that an exact equivalent of an old 18W bulb is dim and yellowish (just like the original 18W was), and want more brightness and white-ness.
Also - want more diffused light. Bulbs few inches above my head with stupid clear lens in the middle of frosted dome cover make for sharp shadows. Nothing beats a shore cabin with normal light fixtures, tall ceilings and 110V grid.
    Then which model with the brightness and whiteness you want? I'm interested in replacing mine but I hear and read people complaining not being bright enough or too blue, thanks for posting and I appreciate your input.
  • RoyB's avatar
    RoyB
    Explorer II
    One bit of caution. I jumped in there and bought about $150 worth of LED boards etc for the whole trailer only to find out that I was very pleased with how they looked compared to the incandescent automotive bulbs but emitted RF signals that blanked out my HDTV and several of my VHF radio equipment including my ham radio.
    This was really a problem when using the OTA HDTV antenna setup.
    I finally fell back to just ordering ONE board that did not have any BUCK REGULATOR chips on it to make the LED BOARD operate in a wide range of DC VOLTAGES.
    After I found what worked best for me and not blank me out with RFI then I bought more of them.
    Just passing on to maybe save you some headaches and maybe some monies...
    The $4.99 boards from EBAY/CHINA was what I ended up with.. All still running great since 2009...
    Roy Ken
  • My plan is to replace everything with LED so I started with one fixture..not sure why I didnt think of just replacing the bulbs. Thanks for the link!
  • LED's were the best mod I ever did. Took a few tries to find the exact lte spectrum I wanted. Changed them all out and have a few spares. Went wth the cheap Chnese units.
