smthbros
Jul 13, 2016Explorer
While I applaud your tenacity in improving the airflow from your AC, I recommend you measure the volume of air flowing (cfm) rather than velocity (mph). When putting a thumb over the end of a garden hose, the velocity of water is increased, however the volume is decreased. CFM is what counts. Also, when turning air thru a duct, the inside radius of the bend is what is critical. Inside radius should be at least half the duct height. Not easy to do in most rv duct systems.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
