Tom_M1
May 18, 2015Explorer
If your WiFi adapter is USB, you could move it closer to the antenna and run a long USB cable. You can go up to 16 feet with a passive cable, 100's of feet with an active. This would minimize your RF loss.
As Jeff noted, your zip-ties will self destruct in a matter of months from UV exposure. At the very least get some black nylon ones which are UV resistant.
While you are on your roof replacing zip-ties, you might want to move the antenna up higher on the mast.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
