rwbradley
May 17, 2015Explorer
Install WIFI antenna on Batwing Mod
I decided to mount a WIFI antenna for those few times when WIFI actually works for me.
What I had:
- WIFI Antenna with N connector
- RG58 cable
- old Linksys WRT54G router running DDWRT configured as a Universal Wireless Repeater to repeat WIFI from campground to Router and than my devices connect to it using my SSID
- aluminum bracket from old network rack mount hardware
- flame retardant conduit putty
What I needed:
- LAP sealant
I decided the best way to do a permanent setup was to use a shelf beside the fridge to put the router on that shelf and run the cable out the side of the shelf into the void behind the fridge to get to the roof. (while I was at it I installed a Wilson Sleek too, separate write up)
1) remove fridge vent cover
2) cut enough of the screen to allow the cable to pass thru
3) drop cable down into fridge vent void
4) cut hole in side of shelf to fridge vent with a spade drill bit
5) fish cable into cabinet using a pull rod (coat hanger would also do)
6) drill hole in bracket to fit N connector thru it
7) use 2 sided tape, bracket and tie straps to mount antenna on Batwing
8) reinstall fridge vent cover
9) cover fridge vent screws, and along the antenna wire with LAP sealant
I found afterward that I had to shave some off the edge of the bracket so it would not hit the antenna head as it came down. That was easy to do with a metal file since I used an aluminum bracket
What I had:
- RG58 cable
What I needed:
- LAP sealant
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
