westend
Mar 07, 2014Explorer
Do the two tracks that hold the glass have anything inside them like a rubber or plastic fill strip? What I would do, lacking a sealing strip in the metal tracks would be to load the track with Mortite. If the dimension of the track is only 1/16" bigger than the glass on both sides and top, you can use some silicone to seal it. In the latter, just fill the track and push the glass into it. If you can, allow some of the silicone to sit on the top and bottom edge of the glass. This is to prevent impact breakage.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
