gaymeadowsman's avatar
May 31, 2017
Installed the Maxxair fan, odd find
This past weekend we picked up the MaxxAir fan, simple 4 seed manual open,to replace the stock single speed fan in our Avenger travel trailer bathroom. With the vent cover over it that little fan barely pulled the steam from the shower out of the room much less drew any air through the trailer.
Anyway, Removal was as I expected except, when I lifted the fan from the roof,there was no Butyl tape. It had the same caulk that was on the top side covering the screws and flange. I don't guess it is anything "wrong" with it,but of all the videos and how to's I had read they all had butyl tape under the factory install. It did make for a longer prep for the new install.
Is this another example of Prime Time cutting corners? I've found a few...
Now I just have to adapt my perfectly good Camco cover to the new fan. MaxxAir fans are now made to only use redesigned MaxxAir covers.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
