philh's avatar
philh
Explorer III
Apr 15, 2019
Installed Vortex II fan today
Installed Vortex II fan in the bathroom today. I did receive instructions... they weren't very good. Mostly useless. It also came with the rotary power knob electrical box not installed. Simple snap that is tough to get lined up and snapped together, but I finally got it.
Instructions didn't tell me if the black or white wire is positive. I guessed correctly, it was black for me.
Had to adjust the crank knob position and when you do, you have to use a spacer... what a silly design that is. I needed a third hand for both the installation and hooking the wire up, and didn't have one.
On high, it is louder than the stock unit, not a lot, but it is noticeable. Medium about the same level, low is quieter. But ****, does this thing move a LOT of air. For that reason alone, it was worth the cost and installation.
  • philh's avatar
    philh
    Explorer III
    jfkmk wrote:
    Philh, black should always be positive and white negative. Although I guess they should have specified that in the instructions.
    I like red positive, black negative in DC wiring :)
    House wiring for this circuit, green is positive, white is negative. In another circuit w/green was positive. I'll continue to be surprised!
  • philh's avatar
    philh
    Explorer III
    GordonThree wrote:
    I've got one sitting in a box, I'm waiting for the courage to break the seal on my roof vent to swap out the factory vent. I put a Vortex III in the bathroom, it was an easy retrofit, fit into the existing frame. Wanted the larger diameter blade of the II for my kitchen area.
    Did you install a vent cover over it?
    Bathroom already had a vent fan. This is a replacement utilizing the existing frame.
    If you're asking did I put a big rain cover over the vent and cover, yes I had previously done that.
  • The multiple speed fans use resistors to select the speed. I bought the single speed fans and used a PWM and reversing switch so that there is variable speed forward and reverse. Doing it this way, it is quieter, more efficient and cost about the same or less.
  • Had one (not a variable speed) in the bathroom of my old tt. I found it easy to install and it moved a LOT of air, although it was a bit noisy. I liked that it was retrofit and went into my existing vent.
  • I put one in my TT a couple of years ago, I also installed louvers on the bathroom door to aid in pulling the air thru the door area. Works really good and a lot more air flow that the original fan. I also installed a vent cover over the vent so it can remain open even in inclement weather.
  • I put one in my last travel trailer. I thought it was a really good fan for the price; it really did move a lot of air.
  • I've got one sitting in a box, I'm waiting for the courage to break the seal on my roof vent to swap out the factory vent. I put a Vortex III in the bathroom, it was an easy retrofit, fit into the existing frame. Wanted the larger diameter blade of the II for my kitchen area.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
