Fire19's avatar
Fire19
Installing a larger Water heater 5th Wheel
I have a suburban SW6de in our 5th wheel and it needs to be replaced I think the Porcelain liner is shot because it it sets for a week I get rusty water. Last fall when putting away I had Blue flecks coming out when I rinsed.. I was looking into upgrading to SW12DE heater I know the opening is bigger and I can make that happen and I have the space. When I called about the water Heater they stated you should go to the 16 gallon for only $75.00 more fits in the same opening as a 10-12 gallon. So my Question is it worth it to have 4 more Gallons??
  • kellertx5er wrote:
    the bear II wrote:
    You might want to look at one of the new tankless type RV water heaters. Truma is one brand.
    https://www.facebook.com/Truma-US-718321218279863/
    Or you could install the 12/16 gallon Suburban and actually take hot showers.
    Have you owned and used a Truma?
  • Tankless won't operate on 120 volts at this time. I'd go for the larger tank with electric and propane.
  • Be aware that while the Suburban 12 and 16 gallon heaters both fit in the same 16"x16" opening, the 12 gallon is 22" deep and the 16 gallon is 27" inches deep. Make sure you have the clearance for it before ordering.
  • when we had the rv dealership they tried to get us to sell the tank less units. they said everyone wanted them. we could not understand that hype talk at all. if everyone wanted them why are they not put into the new rv's on the lot. turns out it was all talk and I'm glad we did not stock any of them. not once while we were there did someone come in and order a new tank less unit. it the space is large enough for a 1 go for it. we had 6 or us showering on a 12 gallon and using electric and gas to heat the water we all had hot showers. plus I like to a nice long hot shower, worked for us. this by the way was in full hookup campgrounds, boondocking is another story
  • You might want to look at one of the new tankless type RV water heaters. Truma is one brand.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
