deltabravo's avatar
Jan 27, 2021
Installing a Water Accumator Tank
I install an accumulator tank in all my RVs not long after buying them.
An accumulator tank eliminates wide variations in flow rate and the constant short cycling of the pump when you have a water faucet only partially turned on.
Here's a video showing how I did it in my ORV 24RLS
  • A great mod, I added one to both of our TTs. Nice when you flush in the middle of the night and the pump doesn't come on right away. A "companion mod" is to add flexible supply line between the pump and the pex tubing, it quiets the pump down quite a bit so the pulses of the pump aren't transmitted to the hard lines.
    Here is the one I put in the Terry, I got the tank at the home center because it was quite a bit bigger than the RV model. Be sure to buy one that is rated for potable water, some are designed only for use in hydronic heating systems.
    Also note that I added a valve to isolate the tank for winterizing purposes so I'm not wasting pink stuff filling the tank.
  • A good follow up project is to put some insulation around any water lines that touch each other, to eliminate noise from vibrating water lines.
    Here's how I did it in the same rig.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 13, 2026
