ScottG
Sep 24, 2014Nomad
I did a lot of research on the subject and found there was one problem with going to an elect. model. The new awning requires there be a header at the top so you can install two large lag-screws (per instructions) that secure the upright arm assemblies. These are critical to support the whole awning assembly.
In my case the framing is aluminum and there was nothing up there but thin alum. channel and rigid insulation.
So there is no easy way to install one on our TT.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
