awhiting80's avatar
awhiting80
Installing an inverter to run my TV and DVD player
My new keystone Outback 210trs is great but it doesn't have any 12v outlets next to the "entertainment" area to plug an inverter in to run my tv and dvd player. I'm looking for a simple (i hope) fix to get a 12v outlet or inverter installed here.
There is a power switch for the antenna with a coaxial cable connection there. I had a similar switch on my last trailer but it had a 12v outlet too and I plugged my inverter into that to run the tv.
Any help or direction would be very much appreciated.
Thanks!
  • First your needs are simple and a small inverter will work fine. But for an inverter, any size, you need adequate wiring from the battery to the inverter. I don't think the antenna wiring is going to be adequate.
    I'd suggest running 12 ga. wire directly from your battery (fused) and grab the negative at the closest point to the inverter or directly to the battery also. OR: if the TV and components are on a dedicated circuit, you could mount the inverter close to the battery and run a smaller wire to the wires that now feed the AC to the TV. Just make sure you interrupt the circuit so you don't have the possibility of two 110v circuits trying to power the same item.
  • You can't use the 12v plug for your inverter to power the TV and DVD. The reason is if you read the fine print (I read mine last night) it says using the 12v plug will only produce 100 watts of power. You will need to run 6 gauge wire directly from the battery to the inverter. Then you should be good to go.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
