Lantley
Nov 01, 2021Nomad
cougar28 wrote:
I installed mine by myself-no jacks or anything. Didn't even take any part of the steps loose. I just removed the old steps-expended the TL steps out fully and put them in position under the opening. Laid under the rv lifted into place-put the back bolts in on each side then the front. Took me all of 30 mins max to install.
Ultimately each installation is a bit different.
My installation wass almost as easy as yours, but mounting the steps was not as simple because I required a 2nd set of hands to insert bolt.
I was almost able to do it by myself, but a 2nd person made it easy vs. a 1 man struggle.
I can see were the OP had to improvise in order to do it solo.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
