Artum_Snowbird
Oct 04, 2013Explorer
The trick with any kind of an anchor is to install another good thick hardwood board with multiple screws into the wall or framework first, then either screw your grab handles into your hardwood board, or bolt right through your hardwood board into countersunk holes for the nuts on the back before you mount your hardwood board onto the wall. This will help spread the load over more of the wall.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
