pianotuna
Nov 02, 2014Nomad III
Hi,
You are over thinking this.
The solar system should be wired directly to the "house" battery bank. It will have a charge controller on it. I would consider adding a trik-l-start or amp-l-start unit so the solar will maintain the "starter" batteries too.
Here is a simple flow chart.
Budget-->Energy Audit-->Battery bank size-->number of watts-->PWM or MPPT. What ever type of controller is chosen, make sure it has adjustable set points and a temperature probe that is on the battery.
One rule of thumb is between 60 and 150 watts of panels per 100 amp-hours of storage. The smaller the battery bank the higher the wattage needed (per 100 amp-hours). Here is a link to the rather special spreadsheet which includes an energy audit, that N8GS has created to help size solar battery charging systems!
Solar Spread Sheet N8GS
For a nice explanation of solar, try this link:
Golden rules of solar
If you plan on full time off the grid, then maximize the solar farm size and lean towards higher voltage panels with an MPPT controller.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
