noteven
Apr 27, 2014Explorer III
Maybe the ABS module is not available just yet? The info for it is on their website.
The test using the trailer brakes only to stop the vehicle had some interesting numbers -
Electric drum brakes - DirecLink controller 259ft less vs Prodigy
ABS/hydraulic disc - both tests using DirecLink controller - 662ft less than electric drum brakes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
