noteven
Apr 30, 2014Explorer III
RCMAN46 wrote:
I have looked into this. First it requires hydraulic disk brakes. Second a hydraulic disk brake pump. Third an ABS module for the hydraulic pump then the Directlink brake controller. Everything except the disk brakes is part of the Tuson system,
Now the problem! None of these items are on the market nor in production. Tuson does not have a firm time line as to when.
I have my doubts we will see the system very soon if ever for the general RVer. One thing for sure the price will be beyond what most will want to pay.
Yes - hydraulic disc brakes are required. The Tuson ABS system includes the rest.
I contacted Tuson - the ABS equipment is available. It is not on their "Buy Now" feature because they want people interested in the conversion to contact them so they can discuss the scope of the conversion & expertise required prior to order.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
