krobbe
Oct 10, 2017Explorer
Zamp Solar has a totally portable 120 Watt kit that you can just clip on to the batteries. Not cheap at $663. And it only comes with a 10A charge controller.
I just installed a Renogy 100 Watt Portable RV Kit for $329 with 20ft of cable and a 30A charge controller. This kit involves mounting the charge controller inside the RV.(I mounted mine inside the forward passthru to be close to the batteries) I spent a good amount of time researching what to use for the plug to connect the panel cable into. I used these SB 50 Connectors and mounted one to the frame for easy plugging.
I spent 3 weeks last summer without campground hookups up in the Canadian Rockies. Could've really used some solar. Was running the Honda2000 every 2 days to charge the batts. Hope this 100Watt portable does the job for next years trip to the Pacific Northwest.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
