andrewh's avatar
andrewh
Inverter, Solar, and Other Power Recommendations
Hello All,
This is my first post on this site, so I hope I'm in the right area.
Last February, I purchased my first camper/RV, a 2015 Thor Ace 29.2, and am now in love with boondocking and traveling the Southwest US. Since I'm quite new to this, any and all recommendations and suggestions are appreciated.
When I first purchased the RV, I swapped out the factory installed coach batteries for a set of 2 12V 100AH batteries running in parallel, since the old batteries didn't seem to be maintained by the previous owner. We do not have an inverter, but I'd be interested in installing one to use for charging laptops, cell phones, and occasionally watching TV. What size inverter would you recommend for the battery setup and for the use that I am looking for? I also wouldn't be opposed to swapping out the batteries for a set of 4 6V if that would seem to make more sense for our use/need. I'm not the most knowledgeable when it comes to electrical installations, but follow directions very well. Is an inverter installation pretty straight forward and can someone with little electrical experience do this on their own?
I'd also be interested in using solar power for charging the batteries. My main concern would be installing panels on the roof and causing potential leaks, wind resistance, etc. Since we tend to boondock in an area for about a week at time, as long as our water/tanks last, I wouldn't mind having portable solar panels that I attach directly to the battery to charge. Would you recommend this type of setup, or should I really look into a roof installation? Considering the mentioned uses and battery setup, how many panels and what wattage would be recommended?
Thanks for taking the time to read this and any replies will be greatly appreciated.
  • If you have a 12v connector it works great filled with a USB adapter.
    I have and recommend a 300 watt GoPower sine wave inverter wired to the one or two strings of general use outlets with a transfer switch. Yes very doable.
    Solar for in use I recommend about 100 watts per battery. Portable is fine to start. You may get bored with the set up etc and just mount some on the roof after a few trips. Your call. Already lots of holes in the roof so that is not a big deal.
    > Members Solar Installations With Pics
  • "I wouldn't mind having portable solar panels that I attach directly to the battery to charge."
    Panels send power to the charge controller not directly to the batteries. You want to stay in camp to watch over your portable panels, fine. Mounted on the roof you can go as you please. Leaks from solar panels? Unlikely if properly installed. Portable panels cost more than roof panels. My wind resistance, as in reduced MPG, is zero and they are right up front on the TT.
  • We have one 135 amp panel that keeps our two 6volt golf cart batteries charged. The panel,is on a 35 foot cabel so we park in the shade and move the panel,into the sun. We only power the electronics for the refrig., led lights and water pump. We also power two cpap machines. As long as we have sun the panel is all,we,use to keep batteries charged.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
