Cummins12V98's avatar
Cummins12V98
Explorer III
Jun 09, 2015
Is it worth $63..............
Is it worth $63, I think so!
The Fan-Tastic Vent Cover is top quality and it actually flows more air by far than the other vent covers. I have used the MaxxAir covers and thought they were good but these covers are superior in every way.
Here is a few pics of the very simple installation. They are available in opaque and smoke.
First thing to do is remove the second screw from each end along the sides. I scraped the old sealant off from below where the brackets go.
Then I covered the cleaned off area with Dicor then installed the brackets with the nice large screws they proved.
Next step is to pick the slots that work best on the sides of the cover to go over the studs on the brackets that were screwed down, have someone open and close the fan to test clearances. Then place the large washers and keepers at all 4 bracket posts. Now you are done and can enjoy your fan even if it's raining.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
