n0arp
Feb 04, 2021Explorer
rdhetrick wrote:
I think that's true if the inverter only has the losses when the compressor is running, but there is a dead load to the inverter even when it's doing nothing. I admit I haven't ran the numbers, but I've got to believe that unless you're turning the inverter off when the refer doesn't need it and on when it does, it's got to use more power over the course of a day.
Of course, but we haven't turned off our inverters except for firmware updates. Our systems (and I guess I should be abundantly clear that this is in no way unique to us) are designed around 24/7 operation in both rigs. If you don't have such a system, then DC makes more sense.
Most of the full-timers we know with moderate to large investments in solar have their inverters on 24/7 and never turn them off except to perform maintenance.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
