woodtrucker's avatar
woodtrucker
JC refrigeration AC or DC upgrade?
Just wondering if any of you could tell me whether I should buy the AC or DC conversion for my dometic rm2652.
We are on shore power almost always except for traveling. Would the truck charge battery enough to keep the 12VDC unit cooling while on the road?
If so, I'll go the 12V route.
Thanks,
Scott
  • jshupe wrote:
    rdhetrick wrote:
    I think that's true if the inverter only has the losses when the compressor is running, but there is a dead load to the inverter even when it's doing nothing. I admit I haven't ran the numbers, but I've got to believe that unless you're turning the inverter off when the refer doesn't need it and on when it does, it's got to use more power over the course of a day.
    Of course, but we haven't turned off our inverters except for firmware updates. Our systems (and I guess I should be abundantly clear that this is in no way unique to us) are designed around 24/7 operation in both rigs. If you don't have such a system, then DC makes more sense.
    Gotcha. I don't have solar on my coach so when I'm boondocking, I turn the inverter off unless I need it.
  • Why I asked about a modified inverter is that I already have one. I want to know if it will run ok on it.
  • billyboy,
    It might. Replacing a compressor fridge would be expensive.
    If it is an absorption fridge, then msw is fine.
    Directly from the product page:
    Converts your existing fridge to a residential fridge (which eliminates your LP gas). This cooling unit is built with a compressor system and not only do you get to keep your same fridge and controls you are used to, but there is no need to remove the windshield or window to get the old fridge out and the new in – nor the hassle of cutting or redoing the cabinets to make a new fridge fit. Also there is no need to have the coach perfectly level for the fridge. It pulls less than 1 Amp and will run off a 600W inverter (does not require pure sine wave). This unit is coated with a corrosion/rust preventive paint, and is very user-friendly to work on in the field should it ever need repair in the future. It is designed to withstand hot/humid temps and will keep your ice-cream hard. Comes with a 3-year warranty. See our easy DIY install video or have it factory installed.
    For questions like this, why not just reach out to them (or look at their site)?
  • We installed the dc version and love it. Ironically we also had to install a small inverter during the process. The newer Dometic fridge we replaced required a small input of AC voltage to trick it into running.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
