houstonstroker's avatar
Jun 03, 2013
Jump Start Battery
98% of the time we either have full hookups or are running the generator full time (NASCAR and Tailgating). However, occasionally (National Parks & Albuquerque Balloon Fiesta ie) there are quiet hours where we rely solely on battery power. I have one battery in the 5th wheel. If it is cold and the furnace blows much of the night I run out of battery power. I was thinking of using one of those jump start battery packs to supplement when we are relying solely on the one battery. I would install Anderson connectors on the inside of the trailer close to the power distribution panel. In the morning when generators are allowed again, plug my jump start battery pack into the wall outlet and recharge. This only happens once a week every year or so. Would this work? The added benefit is if I needed to jump start my TV or someone else's vehicle I would have this portable pack.
  • You have a pickup. Install 2 extra deep cycles in the back.
  • Those jump boxes are only 5% or 10% of the capacity of your existing battery. Good for jump starting the generator but not so much to keep the furnace going. If you have a group 24... go ahead and get two group 27. I get mine at Costco.
  • Just get a second battery and then to ensure the longest life possible and always topped off batterys (coming out of storage) get a small solar panel with good controller (30 to 50 watts should be more than plenty) as a maintainer
  • We installed a total of 4 batteries. Two for lights, pump,refrig and 12v outlets. The other two are for the heater but can be brought in to supplement the other two batteries if needed. For a while we had a 1000w honda generator very quiet that we would run at night when the heater was needed.
  • RoyB's avatar
    RoyB
    Explorer II
    My PLAN B for off the power grid camping is to have a 2KW Honda Generator and B&D VEC1093DBD 40AMP smart mode portable charger.
    I can start up my generator and plug in my portable B&D 40AMP battery charger and usually can jump start any car battery in 5 min of normal charge. The VEC1093DBD also has a 100AMP jump start output but I have never had to use that. Usually when someone runs down their battery I can bring it back enough to get their truck started in around 5 minutes of normal charge mode.
    The second reason I have the portable smart mode charger is I can recharge mt trailer battery bank back up to its 90% charge state in around three hours of running the generator with the 40AMp charger plugged in.
    I can also plug the trailer shore power cable into the 2KW generator 120VAC receptacle using a RV30A-15A adapter ans use the on-board smart mode converter/charger and recharge the battery bank back up to the 90% charge in a three hour generator run...
    Pretty good PLAN B for me...
    Roy Ken
  • Just get a second battery. Those jump start batteries are designed for a couple of starts and not for a continuous draw.
    BK
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
