icanon's avatar
icanon
Just a thought.
I've been wondering and it doesn't mean that I would do it, but wouldn't it be nice to have access under the dinette seat from the outside instead of having to remove the cushions each time? I have a 'U' shaped dinette which is part of my side-out, is it possible to cut and installed an outside compartment door so I can get access under the dinette seat? I wonder how much work is involved and is it doable?
Any thoughts?
  • Our '05 Starcraft hybrid had outside access to the dinette seat.
  • Old-Biscuit wrote:
    Just need the right size compartment door/frame then cut out opening, reframe to have solid blocking to attach compartment door/frame to.
    OR install cabinet door inside to access the storage space.
    See mods this guy has done......HERE
    Thanks for the link added to my favs list.
  • Just googled and found a 2009 Arctic Fox 24-5N 5th Wheel with side out under dinette outside access compartment door, cool!
  • Just need the right size compartment door/frame then cut out opening, reframe to have solid blocking to attach compartment door/frame to.
  • dahkota wrote:
    I think arctic fox has that on some of their trailers. If they can do it...
    Don't know about Arctic fox, will google later but I have yet seen a TT that does.
  • I think arctic fox has that on some of their trailers. If they can do it...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Nov 28, 2025
