DrewE
Sep 24, 2017Explorer III
I'm assuming you're talking mainly about when the furnace is running. If that's true, it sounds mainly like a duct setup issue to me. It might be possible to run another heater duct from the furnace to the bathroom if you have access to the mechanicals without too much effort, or to enlarge whatever one exists (if any). It might also help to restrict the airflow through some of the other registers a little, but be aware of the minimum flow that the furnace needs for decent operation and don't cut it down too much.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
