chast's avatar
chast
Explorer II
Feb 17, 2019
Kind of adhesive?
Newly applied vinyl pin stripping will not adhere in a few spots. Cleaned the area well with acetone, but the stripe still refuses to stick. What type of adhesive should I use to make it adhere without damaging the stripe? I tried a contact cement that is solvent based and it wrinkled the stripe. Any suggestions? Thanks, as usual.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
