westend
Aug 11, 2013Explorer
Most of the articulating arm TV mounts are very strong, over-engineered for the weights involved. The new LED TV's are light, less than 10 lbs. in most cases. I decided to mount the arm on a piece of 5/8" plywood that spans three studs and is attached with six screws into the studs. IIRC, I also used some adhesive. It is rock steady.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
