GordonThree
Jul 10, 2015Explorer
springoflife wrote:
But it raises a new concern. The red tail lens on the left-side of the camper has a small clear spot underneath. The intent is to shine a little bit of white light downward, onto the license plate. Now that the LED bulb inside will be red, will that cause an issue? I think it will give the Plate a soft, red glow at night; which could be mistaken for not being illuminated at all. If a state trooper happens to be driving behind me, will I get pulled-over?
I have that setup, and haven't had a problem over the last few years, covered a lot of miles too.
don't worry about it IMHO
If it really bugs you, you can get a small white led strip and glue it inside the housing, so it sorta shines out that window.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
