ChooChooMan74
Jul 11, 2015Explorer
springoflife wrote:
Sorry if my description of the issue was confusing:
The LED's are bright, and are very expensive.
The turn signals do not flash slowly. The incandescent 1157's actually can't keep up. When flashing, they behave like this - By the time the brighter element is lit, It's time to turn off again. My tow vehicle doesn't flash particularly fast, either, about 1.4 flashes per second with a 50% duty cycle.
My camper (a pop-up) has the same taillights as Choochooman's Roo. Look at the LH lens. See the white light coming from underneath, illuminating the License Plate? Mine will be red,and I wanted to make sure that won't cause any legal issues.
GordonThree, thanks for the reassurance.
If they are indeed Optronics, I would ditch the bulbs, and order a set of lights, and swap out the insides.
Optronics Lights Like ChooChoo's
Here are some Image Links to my Install.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
