Hey guys. I wanted to change out all the bulbs in the trailer to LED. my unit has the 12v Type 921 bulbs. I wanted to know what everyone with this bulb type chose to change it with. How many lumens di...
I replaced all of mine with the bright white panels and I can't believe how much heat they put off! There is enough heat that the glue in the adhesive backing (to hold the panels in place)failed after short use. I'm not sure if I got cheap LED's or not but they are going to have to be swapped out for something else.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: 12 hours ago
