jjj wrote:
I mounted 2 small 50 watt driving lights under my rear molded bumper and also mounted 2 of them on the side just about 2 feet ahead of the wheels and angled them outward to shine on the ground so I can see the ground and the wheels. I mounted the switches,1 for the rears and 1 for the side ones,inside the battery compartment so when I was ready to back up I just turn them on while I was doing my maneuvering and turned them off when I was done. It works for me.
The problem with this is what RoyB eluded too.. Some states which have an "inspection" of your vehicle, the mechanics WILL FAIL the inspection unless you REMOVE said lights or PROVE that they can not be activated WHILE DRIVING IN A FORWARD GEAR. Some mechanics are worse than others so you might find one that is fine with it and others may be sticklers and force you to remove the offending lights on the spot.
Those states which do not have an inspection (and even the ones that do) your vehicle may be pulled over and you potentially can be fined and or or you may need to remove on the spot if your MANUALLY ACTIVATED LIGHTS ARE ON WHILE MOVING IN A FORWARD DIRECTION..
It is a safety thing, blinding other motorists is a bad thing.
It is for that reason any lights which are not facing forward SHOULD BE ONLY ACTIVE DURING REVERSE.
Even pickup trucks with a "cargo" light to light the bed area the lights can ONLY BE TURNED ON WITH THE INTERIOR LIGHTS.. It isn't like you are going to drive at night with your interior lights turned on..
There IS a REASON to the madness and if you understand the reasoning you can safely add additional lighting provided you follow the same rules as the manufacturer..
Pretty simple, rear facing lights if connected to the reverse light circuit and you PROVE they can not be activated in any forward gear will not be an issue..
"Scare" lights are a different creature.. They are not intended to be on during transit and the driver takes the risk of ensuring they are not on while traveling..
