WNYBob
Nov 21, 2017Explorer
I installed strip on my first TC, bought them on Ebay. Silicone covered with a 3M double stick knock off tape backing. I got corrosion under the tape and then had trouble, couldn't get colors to work properly!
On my current TT I got similar strip, but it was inside a silicon tube. No problems so far. I sealed the ends with silicon caulk! I believe the extra cost was well worth it.
I did drill a hole 5/16" I think, pushed the connector through and used silicon caulk again. (It's under the awning so it is somewhat protected)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
