beemerphile1
Nov 24, 2017Explorer
Jeffreykell12 wrote:beemerphile1 wrote:
I drilled a hole thru the sidewall where a kitchen cabinet was on the inside. Added a switch and made my connections there.
After you drill the hole hell did you transition the wire through the wall? How did you properly seal the opening ?
Caulked around the wire filling the hole.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
